I did a bunch of searches with the keywords 'water pump', but didn't turn up the kind of 'how to' advice I'm looking for.
I have a coolant leak, somewhere near the front of my engine. The fan sprays it all over. At 100K+ miles, I figure a water pump and thermostat replacement wouldn't hurt. All the hoses are fairly new silicone, so they should be good.
I bought a water pump and thermostat kit from Genos.
The factory service manual takes the approach of replacing the entire cooling system - I just want to do the water pump and thermostat. I figure I need to drain the coolant down from the radiator petcock and remove the serpentine belt (replaced it recently too).
Do I need to remove the engine fan?
Are there any special considerations for the o-ring, I don't see a gasket indicated?
Being quite familiar with all my hand tools, how long should this job take me?
I have an inch-pounds torque wrench and the torque spec for the mounting bolts.
Thanks,
Boondocker
Thanks,
Boondocker
