2nd Gen Non-Engine/Transmission What and where is a good track bar and ball joints?
Engine/Transmission (1994 - 1998) overdrive missing?
Engine/Transmission (1998.5 - 2002) Smarty pants
Where do you fine gent's reccomend to purchase a new track bar and some front end ball joints for a 02 TDC 4X4 2500? My truck is stock.
Thuren Fabrication-home page for the track bar. Very solid unit and excellent service. If you decide on this unit make sure you accomplish a clearance check with the differential cover.
Arrow Alignment in Las Vegas installed my adjustable joints, not sure who the source was.
JJ
Ive had a thuren bar on for 40,000 miles and the steering is still great. On an 02 the frame swivel of the track bar is apt to hit the front differential. To rememdy this you would have to install some type of leveling kit. There was a couple tests that can be done to see if the bar bolt will hit the differential and mine passed. When you hit a large dip or massive pot holes is when contact occures. By all means contact Don Thuren and discuss it with him if you want a thuren bar.
last summer when i overhauled the truck i used ball joints from quad 4x4 and did the gen 3 track bar upgrade. i liked it because it got rid of the ball joint that fails. my steering come from bulletproof steering and i sent them my gen3 track bar and they made me one bent up with beefy joints on both ends. chrome coated DOM tubing its solid as a rock. also u might think about a steering stablizer from DSS/solid steel industries. hope that helps
