Competition What happens when you make more power than your drivetrain can tollerate.
Off Roading i.f.s. swap out
Competition How much horsepower does this have?
Comp, you're dead on and a great post. Uh, two post.
And just a question, on a sled pulling truck, if they had a vibration such as a drive line type, would they ever feel it, runnin 55 MPH, bounding like a frog with his rear on fire? I just don't see how the two different events can be equated. That is compared to each other. Two different needs and uses.
. . Preston. .
COMP461 said:
... I guess I should just let them fix problems that don’t really exists , and not give them a few tools necessary to run fast.
4 tenths are a lot to make up
Greg... I never said the problem does not exist. Look at the photos... there is a problem somewhere. When you boil it down, Keating does not think it to be the pinion angle. He has had input of others which agree with him. I trust Keating... he is absolutely one of the most intelligent, sharpest people I know. And I know some doozies. Apparently you have enough trust in Keating to run one of his billet thrust plates in your new motor. Suprising where things come from, huh?
Not at all, its Enterprise cam retainer, Buddha makes them, and so dose Enterprise, since them I have gone to a straight cut gears. I would assume by this comment Keating Machine dose those for Enterprise
COMP461 said:
Not at all , its Enterprize cam retainer , Buddha makes them , and so dose Enterprize , sence them I have gone to a steight cut gear ,
It's a Keating Machine product private labeled. More comes out of this little shop than a lot of people might know about.
biggy238 said:
What's the mechanical basis for the straight cut gears? It's something I haven't seen mentioned in the other discussions.
I think he is talking about the thrust produced by angle cut gears.
"NICK"
MMcfall said:
New guy to the forum but just wanted to add something to consider - From an engineering standpoint a foot pound of torque is a foot pound of torque no matter if it is from a gas, diesel, or turbine engine. I think the big difference is the rapidity that torque is applied. It would be interesting to see dyno charts of gas, and diesel drag engines and see how fast each one puts on the torque.
And don't forget the periodicity of the torque. That is, torque is generated in pulses. The *measured* torque of an engine is an average of the torque applied to the crank.
Using Greg's engine numbers, in an engine making 1000HP at 4200 RPM, each piston produces around 8. 75 power strokes per second. In an engine making 1000HP at 8000 RPM, each piston produces around 16. 67 power strokes per second. The slower engine produces a lot more torque per power stroke at a greater interval, which means much more shock stress on the drivetrain components.
Let's look at it slightly differently. The slower engine produces 1250 lb-ft of torque, while the faster engine produces 656 lb-ft of torque. Assuming the engine is running steady state, this means that each engine generates that torque during every 2 revolutions. Also assume that, at any given moment, only one piston is producing the majority of the torque. On average, each piston in the slower engine produces 1250 lb-ft of torque on the crank, while in the faster engine, each piston produces, on average, 656. Here, I'm going to pick a factor: to maintain an *average* torque, the peak cylinder torque must be much higher; I suspect each piston's peak torque may be around 80% higher than average. That means the slow engine is producing 2250 lb-ft of peak torque per cylinder, while the fast engine is producing 1180 lb-ft of peak torque per cylinder.
Math says, if I computed correctly, that the slow engine is producing 280 'pulses' per second of 2250 lb-ft of peak cylinder torque, while the fast engine is producing 533 'pulses' per second of 1180 lb-ft of peak cylinder torque.
Seems to me the slow engine produces a lot more shock stress and allows more 'unload' time between stresses than does the fast engine.
Now consider the difference between SI and CI engines. Typically, the CI engine produces power during a longer stroke; hence its superior torque capacity. But this reduces the peak torque; let's say it's near the average. The diesel engine is producing a smoother, more constant, torque to the drivetrain, while the spark engine produces a pulsy torque. An analogy might be that the diesel is like using a lever to press-fit a bearing onto a shaft, while the spark engine is like using an air hammer to install the bearing.
The point of this mental exercise is to show that diesels seem to produce a different 'quality' of torque than do spark engines. Perhaps diesel drivetrain components don't need to be as hard as their spark engine counterparts; they don't suffer as much shock stress. And perhaps they do need to be as hard, to stand up to sudden loading shocks found in motorsports. But, diesel components do need to be tougher so they can handle the more constant work loaded on them.
These are some very good points. Good write up fest3er
Not to push thins to far to the side here. But some of the high end motors that comp was talking about (2500/3500hp alki burning ones). Do they not "diesel" some/part/most of the way down the track since these motors essentially burn the spart plug off? Or is this just in the top fuel 6000hp+ motors? If this is the case, could this change the stress "style" to what fest3er was talking about?
I'll throw this out there for thought:
The fabricator I am using called Strange Engineering yesterday to discuss ordering a 9" housing for my truck, and they told him that they didn't make a housing that would not explode when exposed to the torque my truck is making. Mine is only making around 1500 right now. They said there axels (40 spline) would hold up, but not any of the housings that they made.
Ted
Ted
Ted- What about one of them fabricated housings that use the 9" center section?
And yes- the rifle drilled, 40 spline, axles are strong as heck!
not sure exactly what he asked for, but I was told that there best housing, which I think is around 1700 for the housing alone, would not hold up but they would do some research into some of there other housings and get back to him.
An alcohol motor dose not burns the plugs off, unless it’s also burning the rest of the motor up. A top fuel motor is the same it relies on the plug to ignite the mixture, hence the pair of 90 amp ignition boxes that will generate enough power to light a good size house.
I do not believe there is anything magical about diesels or the kind of power they make, its all just power, and conditioned properly it applies the same load and stresses on a drive train that any high end gasoline of methanol motor dose. This is the primary reason I am currently fast.
I do not make a distinction in the type of fuel or method of ignition used. It’s just a FOUR STROKE, INTERNAL RECIPROCATING ENGINE. There are no special attributes. Now as to whether a Strange component will hold up, the answer is yes, if you are truthfully with them, and not do like EDGE did, with every one they dealt with in building the Weasel.
A 1500 FPT motor in the minds of a rear end manufactory would be making 1500 to 2000 hp. In drag racing we are never looking at peak torque as a factor if you truly want to be fast, I’m sure if I pulled my motor down low enough it also would make that amount of torque, but why? At that low rpm it would not be making much hp, and hp is the only measure of drag racings assault of the quarter mile. At that low a rpm you also start to unit load the motor as in head gaskets blocks and rods. But I have take another approach to this keep on with what you are doing , and you will get what you are getting , broken parts , and quarter mile time that don’t get you the record.
I run a strange 9 ½ inch A/FD chunk , and its hold up fine , I check them ever 2 or three passes , and have as of yet not seen anything that would lead me to believe that it will not hold up for a good while , if I get 50 laps out of a set of gears then I feel its worth it.
Hey COMP, yawn.
You still don't get it, and never will, and thats why all you ever ran was a good 9 second run, and its doubtful if you will do it again. Downhill track, maybe.
A 1000 hp. gas truck can run a 14 bolt corp. rear a whole season without issues but a 500 hp diesel will spit it and dana 70's out like they're candy. I suppose the couple of gas guys are smart and the 100's of diesel guys are dumb. Yea there is no differance in the power----your right.
