Labonte18 said:
i kinda have a queston along the same lines, want some other ideas... what air-intake and ram-air hood work together for a '03?? i want a functional ram-air hood that works with a good flowing air filter and box???thanks robert
This has been my experience, FWIW:
I originally bought an AFE Mag Force with the original Torque Tube. I was not told about the pre-filter. I ran it for about 5k miles through the winter. It was raining a LOT. I checked the filter one day, and it was completely soaked with water. I was disappointed.
Later that week I pulled the Torque Tube and found the inside was not powdercoated, and that it had corrosion all over the inside. You could flake the white powdery stuff off very easily. (newer Torque Tubes will not have that problem because they're plastic) I decided to have the Torque Tube powdercoated inside and out. I also added a pre-filter.
At the same time I checked the turbine blades. They were sticky and black. That lead me to believe that my engine ingested some dust at some point after the filter had been soaked a couple times. I believe that the water displaced the oil reducing its effectiveness.
I ran the pre-filter and powdercoated system for a while, and found that the pre-filter is largely useless in '03 trucks ('04's may be the same). The filter was still getting soaked.
There is no shroud between the CAC and the headlight in the early 3rd gens. It gives fresh air a direct path to the AFE filter. It's like built-in ram-air, but it's also a ram-rain and ram-slush. The pre-filter simply cannot keep that much water out.
I like the AFE system. It flows well and sounds good. I just needed to find a solution. I went to a plastic store and purchased some 1/8” thick polycarbonate. I then cut it to fit the area between the A/C condenser and the headlight. I heated and folded the edges to keep it from flexing and letting water by.
After driving through some of the worst weather in a long time here in Northern California, I can tell you this is the solution to wet filters. I drove through extreme rain, streets that were flooded with 1-1/2 feet of water (several miles worth), and two snow storms.
I checked the filter periodically, and there were only a few drops of water on the pre-filter. I’m now a happy camper
But you can be sure I pull the shield off in summer to get cold air to the filter.
The newer trucks already have a plastic shroud, so I’d bet they don’t cause the filter to get wet in the same way.
