Does anyone know the part number for the OE brake pads? I have an 02 with 4 wheel disc brakes and I am about to do a brake job.
Geno's Garage carries the Mopar pads. Go to Dodge Ram Brake Pads and Accessories-Dodge Cummins Diesel Truck Accessories – Geno’s Garage and click on the appropriate MOPAR VALUE LINE pads. You'll find the Mopar P/N to the right of Item Number : BRAKE
You can also compare your dealer's prices to Geno's.
The Performance Friction Carbon Metallic pads, have been the second worse pads that I have ever had. I know there are different versions of their pads but I don't remember which ones I used.
The worse pads were the EBC SUV Supreme pads, I removed them after 15k miles. The funny thing is that the EBC Extra Duty SUV pads are the second best pads that I have come across.
The best pads, from my experience, have been the Bendix TitaniuMetallic II pads. The only problem is that I can no longer find them locally in San Diego and I have to order them when ever I'm doing a brake job for some one.
Pablo
Hey y'all--
I've seen the positive comments on Hawkhead brakes, and read the police car brake tests. I'm ready to buy their pads. Since Hawkhead is based in Florida, as am I, I contacted them via the web page someone posted above to see if I can buy them locally. They referred me to their nearby distributor, and this is where the confusion starts:
You've reported that Rapid Brake in WA sells the pads for ~$65. The Florida distributor only charges $25 + freight! So I have to wonder if these are the same pads! The FL guy says they're ceramic. He also says they're "cheap pads", made in Mexico. He thinks I'll be happier with Raybestos.
I found an old post that gave the Hawkhead CarboMet part number as BRACMD459. I'll call the FL guy and check this number with him. Is this still the number everyone is using?
thanks
kevin
Kevin
I'm sorry about the delay in getting back to you... I retired and closed the shop in Sept 2010... its all gone... I've been enjoying the good life in AZ the past few months and just opened the TDR websight for the first time in months... I've got a lot of emails...
Sorry for not getting back to you and I'm sorry that I can't help...
Jim
Hahha! :-laf Never replied to myself. Here it is ... 3 years later and 119,000+ on the odometer and I am just now getting some little bumping when I step on the brake after some panic stops when loaded I guess, rotors must have taken some real heat cause no time to downshift or let the exhaust brake work. Pads and rotors still have material sufficient as just got my PA inspection done. Soooo will be in the market for replacement. Back brakes are fine. A true testiment to my turbo exhaust brake and driving habits i guess. I use exhaust brake contantly and always downshift. No hot rod type activity. I never thought I would ever be close to the same mileage wear category as these other big guys. Go figure.WOW! You guys are blowing my mind here. Simply Amazing stories. I do believe all of you too. I am now looking forward to seeing how long I can make these brakes last but the PA inspection stations might have something to say about that. Thanks for the interesting feedback! Good stuff indeed!
