what is it worth, (a enclosed trailer)
Ceiling Fan Blades Keep Breaking Off
Fresh water tank sensor install
I have option to buy a Roadmaster trailer
specs are as follows:
6x12x6
single Dexter axle rated for 3500 lbs.
Upgraded suspension
rock guards
rear has 2 doors
side has 1 door
lights
Centrifical brakes??
(No controller used)
uses 2" ball
trailer rated for 2990 Gross Weight
Dealer says 3500 lbs is ok (due to axle rating)
approx 900-1000 lbs empty
painted spoke wheels
4 Pin harness
Seller wants $2,000. 00
now he says $1,600. 00 (After taking to dealer for valuation)
Was $2,295. 00 New
What do you think??
6x12x6
IMHO - I wouldn't own a 6x12x6 with only a single 3500# axle unless I was only hauling a couple of ATV's or Motorcycles. Anything heavier like filling it with building materials could overload it.
As for pricing - Depends on the overall condition and what you think an enclosed trailer with 2000# capacity is worth.
I have owned several enclosed trailers and can tell you that is a very good price when compared to new. I use mine to haul dirtbikes so I don't approach the 3500 lbs limit. If you heed BV's advice and don't overload it, it'll be a very good deal.
Pat
2001 QC, 4x4, ETH
Since the trailer has surge brakes, I don't know why the GVW is 2900 lbs. It should be the axle rating, 3500 lbs.
The Mfgs. use the 2900 lb rating to squeak under the Federal limit of 3000 GVW for any trailer built without brakes, regardless of the axle rating.
$1600 for an enclosed 6 X 12 sounds like a good price, though. Just check the condition of the flooring and frame.
I have a similar trailer. It is a Haulmark V-nose. It has a ramp door and interior lighting (nice). It does not have brakes. Other than that, it is the same as the trailer you describe.
I paid ~ $2500 new in 2000.
