What is this? (see picture)
What would I be better off doing?
Lugging ETC in 5th gear ?'s
What is this bolt for? What's under it?
If it is oil... can I use it for tap point for older style amsoil bypass filter?
Thanks.
oh yes there is oil there
looking at the service manuel page 9-231
I am not expert so I will give no advice if this is the best place to tap in.
Search the archive using Amsoil bypass filter and you should find a bunch of reading
It is an excellent port for an oil temperature sensor as it leads to the oil galley that feeds the turbo. I am not familiar with the Amsoil bypass filter, so I cannot comment on whether it can be used for this purpose or not.
I was told it was a port for an oil temp sender used for overtemp shutdown applications like stationary generators and the like. I use it for an oil temp sender too.
