what next?
Broken trailer tow mirrow - fixable?
Weird A/C Prob with my '06
a little less than a year ago I replaced all the rotors and pads... . It started to slowly show some warp age on the new brakes... . then my caliper went and locked up it turned the rotor blue so I assumed that was the bad rotor so my rotors had a 2 year warranty and the pads have a 3 year I warrantied the single rear rotor and by god the pulsing is still there..... so now Im going to have to warranty the other 3 rotors and get new pads since they are still under warranty... . will this streak of bad luck ever stop on this truck... btw by bad luck I had to replace the steering ,the brakes and now my exhaust just cracked on the way home from work all in 2 months :{:{
The blue rotor is from heat caused by a bad caliper and the warp is from the heat.
Ron
yeh i know I already replaced the caliper and that rotor pulsating is still there I assumed it was from the same rear brake that was causing the issue... .
WOW... ... ... ... ... ... . How many miles? My 03 has more than 90K and I just checked the brakes this past week... ... ... ... ... ... ... ... ... ..... they all look very good with very little wear! With that said, I do have an exhaust brake, which does help extend brake wear.
95k no engine brake and don't tow
