Engine/Transmission (1994 - 1998) What parts do I need from Cummins for timing advance?
Engine/Transmission (1994 - 1998) KDP Jig Keeper in SE area
2nd Gen Non-Engine/Transmission Fender liners
I borrowed a timing set from a friend yesterday. Trying to get the truck back together. In the meatime, I am going to try to bump the timing on up since I am putting 370's back in. (when I read and figure out how to do it)
Anything I need from Cummins. I am going to go ahead and get a new lift pump and put it on. Already got the new fuel lines on.
I ran a search and someone posted that you would need delivery valve washers & O-rings. Do I need these and if so how many?
Appreciate any help,
JD
You won't need DV washers unless you're changing the valves. You might want to add a new overflow valve if you've never changed yours. As far as timing, a new nut and washer for the pump gear if you have to change the timing.
Bosch now has a steel washer that replaces the copper del. valve washer. The o-ring is good to have on hand cause Mr. Murphy might visit. It just takes a small nick to give a leak. Chances are, have the parts on hand and you will not need them.
