What the heck is it?
Questions about tst #11 plate
Ignition Wiring
On the drivers side of my hood in front next to the hood latch, I have found a doohickey that looks like the south bound end of a north bound mechanical pencil. It has a wire that connects into the wiring harness behind the underhood lamp. I’ve looked in my truck owner’s manual and see nothing that resembles it.
Sooo what is it?
:eek: :eek: :confused:
That little thingy is the temperature sending unit for your overhead console thermometer. Aint technology sumpin'?
Temp. sen.
I agree its the temp. sensor. Isnt this a great site, theres allways someone who can answer just about any question you can think of. Agreat bunch of guys , I have learned a lot from them all. Thanks fellows. Charles. :D
Well now everybody knows I have an over head console in my truck. Ya ask the wrong question around here an everybody knows yer business, no secrets from you guys. Hey Thanks for the help. :p :D :D
Heres the part I don't get... Why is it mounted under the hood?... ... ... Is that why I get high readings sometime? Seems like it should be mounted elsewhere..... Just curious... .....
Colin
Colin-
I think they mount them there so they will be protected from the outside elements, (ice, etc. ) but will still read incoming air temperature while going down the road.
I have noticed mine doesn't always read correctly until it's driven a few miles, especially if the truck has been setting in the sun.
Dave
ETH, I was thinking the same thing the other day, by another sender and somehow mount it in the intake pipe, or find the range that the sensor works in and get one with threads on it. That way you could have a switch to check the outside temp or intake temp.
I think when your sitting still engine heat drifts up to the sensor and raises the temp some.
Bought one of those for someone one time, it was only $11. But the dipstick for the cummins is $30!!! That was backwords from what I thought it would be
Clark
