My first dually. Loaded I'll be pulling a 15,000 lb 5th wheel. Came with American General tires, and the door sticker for tire inflation says loaded to run 60 lbs in the front and 65 lbs in the rears.
Question is for you all, are you running the 60 and 65 or do you suggest increasing it? When I had the valve stems changed to metal, the tire place put 70 and 75 in them.
Also, if your not towing often, do you decrease pressure to light load?
