What tool to use to remove drain plug?
Front Brake Dust?
4WD Universals
Help, I have broken 2 wrench socket extensions in the female drain plug! Does anyone know the proper tool to use? Thank you in advance (as I am under the truck now).
need to use something other than a "made in taiwan" extension , my crapsman hold up fine , are you turning it in the right direction ? #ad
... righty tighty , lefty loosey
[This message has been edited by Mopar-muscle (edited 09-23-2000). ]
I use a Craftsman 1/2' to 3/8' drive socket and use the big 1/2' drive to turn it. never had a problem . If you are breaking off drives in the pan bolt then you might be cranking it down to hard. Dont strip out your pan!!!!!
1999,2500 (white)4x4,QC,LB,ISB,AUTO,3. 54's Track Loc, All options except leather,Factory Flares(Black),Tow package , Camper package, Rhino Lining(Black), 285/75r16 ,K&N Filter, Waiting to BOMB the heck out of it(I need your inputs first !!!)Based on many inputs(THANKS) Bill K's TC and valve body,P. E. fueling box, DD stage 1 injectors, Psychotty air, Jardine 4'' exh. Autometer Egt,50 psi boost, trans temp Guages dash mounted with Autometers triple mount.
In the process of putting it all together!
DON'T torque it over 40 lbs when you put it back!! The manual is wrong where it says 60 lbs! #ad
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
I use an actual 3/8" sq socket I bought for other purposes in the past. The Snap-On man told me that he saw a lot of square drives broken on plugs because they are not as deep as socket therefore placing more stress on middle portion of the square where the ball is. Never happened to me but it does make sense.
2001. 5 2500 4X4 SLT, HO 6spd. No BOMBs as of yet, 1K 091700
Buy the Finger Touch drain valve from Geno's. It works great! Put the drain pan under the truck, flip the valve, go do something else. You won't even get your hands dirty except for handling the oil drain pan.
I agree whole-heartedly with installing Geno's Finger Touch drain plug. Another benefit is how easy it is to get a midstream oil sample without any mess. #ad
1996 Dodge 2500 4X4 SC, SLT, Cummins 12V, 5-spd. , JRE 4" exhaust (my kitty ran off into the woods and the muffler fell off!), TST 280 HP/685 Ft-Lb Uprate Kit, AFC Spring Kit, Horton Fan Clutch, Jacobs/Ram Exhaust Brake, MagHytec Differential Cover, Prime-Loc, Rancho RS9000 Shocks, Combo Gauge, K&N Air Filter, Brite-Box, Geno's finger-touch oil pan drain plug, no turbo silencer ring, full-time fog lights.
Thanks to all. I went to Sears and bought a high impact tool ratchet. It was perfect. I think next time, I'll pay the $39 and have them do the oil change. Between the cost and time, I think it's a good value.
If they use the right oil, dont forget to prime the oil filter and remember to tighten and/or not over tighten and strip the drain plug!!!!!!!!!!!!!!! just remember the oiler is not a mechanic, gets near minimum wage and just does not give a hoot about your $35k+ truck.
my opinion
Joe Saturday (diy) visits my shop every Monday morning. You the one who blew up your truck? The warranty issues, bombing truck and blowing it up. Mad about no warranty
HAVE AT IT jOE SATURDAY, OBVIOUSLY YOU CAN DO NO BETTER THAN THE SHOPS YOU REFUSE TO FREQUENT.
I truly don't mean this personal as i dont know you, but i feel you are not in the position to chastise other people's work or shops
B... ... ... ... ... ... ... ... .
I've got to agree on the drain system from Geno's. I've bought a lot of stuff for my truck, but $for$, that has to rank right up there with sliced bread.
Get it and use the instant change places to dump your used oil like I do.
Chas
I may not be much, but I'm all I think about.
95 that is lightly used. Dressed out nicely with 19. 5 wheels from Rickson Truck.
I use 6 tools to do an oil change a SnapOn 10 inch swivel head 3/8 ratchet, 8 inch extension, SnapOn strap oil filer tool, creeper (if on the ground), drain pan, and funnel. . 15 min job at most. I do not understand what the problem you guys are having changing the oil filters.
I move the strap up to the very top under the oil filter band and although it is tight it comes right off.
I could not find Geno's, yes i am fairly new to this area.
What size threads are on the plug??? can't i get a valve a the hardware store?????
96 CC 4X4 2500 SLT AUTO transmission, PrimeLoc, GUTTED CAT, Lots of Ham Radio gear, NO IGNITION NOISE!!! Love my diesel!!!
Geno's Garage
You an order them straight from the website I think. Still haven't gotten around to ordering mine.
Curtis Harris
FOR SALE
"Big Red" See Truck for Sale
MY NEW TOY
1997 Club Cab Dualie
correctly valved 5 speed. White, Brown Manf. brushguard,Sprayed in liner, Stock plate and AFC properly adjusted. That all for now. More to come.
