03 turbo
Greg, you ONLY get to 1300 running wide open throttle, what is a high number if only 1300 is low. If I am cruising empty between 60 and 80 mph. I run between 600 and 850 depending if it's flat or I'm going up 6 to 7% grade,I didn't realize you all were that interested in what the temps were just cruising empty. I don't really do much cruising when I'm going down the road at 32,000 pounds where I live you are either goiung up 7% or going down 7%. When I do hit a flat stretch going 60 to 65 it will run from 800 to 1050 depending on the little grades, it will only hit 1300 going up long grades of 6 to 7% I was just giving you extremes.
Dan you are right about DD injectors and other people selling them, I never said they were bad, I don't think you should be so quick to judge DPU, you said yourself you never heard of them or does that alone make them bad. Also Piers sells the B-1 turbo do they sell the turbo that DD sells?
Vaughn, I don't know what happened to the DPU website I'll try and find out. It is the same outfit that installed Dr. P stuff before I guess that is enough to condem him huh. Maybe you should check and see what Mark at DD did before he hooked up with Lawrence. I have had a B-1 on my truck and it had to much lag, I don;t think I'm at the upper end of the KSB-1 because I know of people with 550 to 600 HP running this turbo. These are all just my observations so think what you want. There are alot of good people out there and alot of bad just be carefull and find someone you are comfortable with. JUST MY OPINION.
