Details here: TDR Privileges
You should be good at 16*. That's what mine is set to. You can go higher but at the risk of blowing a stock head gasket in the long run. If you have o-ringed your head and/or have a thicker head gasket you can safely go a little higher
Indurbin, Did you see an MPG increase when you changed the timing. I think that my timing has slipped back a little or my stock injectors are worn out.
