Where does this alternator cable mount?
ready for new turbo..what to get?
Need help in VEGAS
Not that senile yet, but I took this apart a month ago and have worked on 30 other vehicles since. Need to finish this engine and the bend of the cable isn't indicative of where it should mount? I assume it's a ground cable so about any engine bolt would probably do, but I like to get things right.
Any help is appreciated.
Mine snakes around the back side of the alternator, passes forward between the alternator and the block, and bolts onto the thermostat housing, just under the upper radiator hose on the front side of the motor. There should be a single bolt there. Hope that makes sense.
AJ
