Engine/Transmission (1998.5 - 2002) Where to get Holset Parts?
2nd Gen Non-Engine/Transmission heater restriction
2nd Gen Non-Engine/Transmission Convert from CAD to Non CAD
During overhaul I discovered that one of the c-clamps that hold the exhaust turbine housing to the main body is missing (as is a bolt) and that the metal gasket between the exhaust housing and exhaust pipe (5 bolt gasket by waste gate) is cracked.
I need to locate a source for these parts. Anyone?
Please provide your Engine Serial Number, I'll look it up here at home and give you current part number and prices.
If is not the stock turbo, then will have to do something different.
I'll be on for another 1/2 hour or so if you want me to try it.
Mike.
This is the parts breakdown for a HXY35 Holset. No illustration will come up for me tonight, will try to score a matching picture from Cummins tomorrow if you want. Let me know. Will need your ESN as well.
In otherwords you can get it all at Cummins.
For this turbo the gasket is 3535001.
The bolt would be 3759917.
Clamping plate is 3534309.
Mike.
Parts Catalog - Option DetailContent For Engine Serial Number (ESN): 56569363
Electronic Parts Catalog - Option Detail
Option Group Graphic Film Card Date
PP97476 10. 06 null T 19-DEC-00
Engines G5. 9, B4. 5s, QSB5. 9-44, QSB5. 9, G3. 9, B5. 9 G, ISB CM800, ISBe CM800 (4 Cylinder), ISBe4 CM850 (4 Cylinder), ISD6. 7 CM2150 SN, 6B, B6. 7s, B5. 9LPG, B LPG Plus, B4. 5, ISB CM2150, ISB CM850, B Gas International, ISB6. 7 CM2150 SN, B3. 9, QSB4. 5-30, B Gas Plus, QSB6. 7 CM850, ISDe CM2150, 4B, ISBe CM2150, ISB4. 5 CM2150 SN, ISD CM2150 SN, QSB5. 9-30, ISF3. 8, ISB CM550, ISBe4 CM850 (6 Cylinder), ISBe CM800 (6 Cylinder), QSB4. 5 CM850, B5. 9, ISBe CM850, QSB3. 9-30
Ref No Part Number For-Sale Shopping Cart Part Name Required Remarks
PP97476 NO Turbocharger Turbocharger
3800397 YES ADD Turbocharger 1 Recon Equivalent 3800397 RX
3590104 NO Turbocharger 1 Serviced as 3800397
3503100 YES ADD Bearing, Turbocharger 2
3519163 YES ADD Screw, Drive 2
3519302 YES ADD Shield, Turbocharger Heat 1
3519336 YES ADD Shaft & Wheel 1
3522597 YES ADD Pin, Roll 1
3527566 YES ADD Ring, Retaining 1
3527619 NO Dataplate 1
3528104 YES ADD Baffle, Oil 1
3528177 NO End, Adjusting Link 1
3528221 YES ADD Ring, Retaining 1
3528933 YES ADD Seal, O Ring 1
3530556 YES ADD Screw, Hexagon Head Set 5 M8 X 1. 25 X 20
3530923 YES ADD Plate, Oil Seal 1
3530924 YES ADD Slinger, Oil 1
3531238 YES ADD Ring, Retaining 1
3532215 YES ADD Bearing, Tur Thrust 1
3532217 YES ADD Collar, Thrust 1
3532310 YES ADD Impeller, Tur Compressor 1
3532427 NO Baffle, Turbocharger Noise 1
3533163 YES ADD Ring, Retaining 1
3534309 YES ADD Plate, Clamping 2
3535001 YES ADD Gasket, Adapter 1
3535215 YES ADD Clamp, Hose 2
3538468 YES ADD Hose, Plain 1
3539944 YES ADD Housing, Compressor 1
3539951 NO Housing, Turbine 1
3590111 YES ADD Pipe, Exhaust Outlet 1
3590306 NO Nut, Lock 1
3591573 YES ADD Pin, Roll 1
3591574 YES ADD Housing, Tur Bearing 1
3592050 YES ADD Nut, Hexagon Flange 2
3592805 YES ADD Coupling, Elbow Hose 1
3594915 NO Actuator, Turbocharger 1
3756754 YES ADD Seal, Split Ring 1
3758848 YES ADD Seal, Split Ring 1
3759917 YES ADD Screw, Hexagon Head Set 4 M8 X 1. 25 X 12
3762259 YES ADD Ring, Retaining 4
Thanks for the reply.
Surprisingly I found that Cummins could supply me the gasket. (I didn't know Cummins owned Holset)
The clamp is not available from anywhere so I fired up the plasma cutter and made one.
Everything is back together and running.
Well, back to square one. Looking for the clamp in the photo. I have not been able to find this clamp nor successfully describe it. So, here is a photo of the one that is still on the turbo. I fabricated one but it has "disappeared" along with the bottom bolt.
I never did get your ESN, but really should to be 100% sure.
If your turbo is the one I used for reference then... ... ... .
Cummins Northeast has a clamping plate in stock at the Buffalo, NY store.
They also have 4 of the bolts at that location.
I can check their inventory from home, just can't check the factory's stock.
Get me your ESN when you get a chance.
Mike. :)
Sorry, I thought I had sent that. Must have been suffering from "olds-heimers". I appreciate the help.
Doug,
There is no graphic for the parts list I provided in December above, however the part numbers are correct for your ESN, I always feel better double checking before I pronounce etched in stone part numbers... ... ... ;)
I did take the clamp number and went backwards in the Cummins program until I found a graphic of a turbo that uses that part number just as a reference tool. Even though the graphic is not for your specific turbo it still uses the same clamping plates and bolts as yours.
I have attached it here.
So the part numbers I have provided are good, you need (1) 3534309 Clamping Plate and (2) 3759917 bolts. Items 22 and 24 below.
Let me know if you want me to have Cummins Northeast check factory stock on these parts in the morning, then you will be able to pick who you want in Illinois to order them from Cummins for you.
Mike. :)
Just called Cummins Northeast and had them check factory stock, Cummins Plant in Tennesee has several plates and tons of bolts on hand.
Pick who you want to order them for you, if you don't have a Cummins Distributor close by then try an OEM truck or equipment dealer that sells or uses any Cummins B or C powered products.
Mike. :)
Great! Thanks for all the help Mike.
I've got a couple of distributors I can use so long as I know what I want.
I'll give them a call this morning.
