Where's the boost?
Leaking oilpan plug
Test Drove Duramax/Allison, Not impressed.
Fellas,
I think I got a problem somewhere. I put on the EZ along with the adjustable elbow,I cranked it all the way closed,and I'm seeing only about 19 psi. That is all I was seeing with the engine stock. I checked all the hoses, and they seem ok. Any ideas. I can get to that 19psi in a hurry,but that's about it.
Help
Big A
'99 3/4 24 valver Quad,auto,KN stock, westin powder blackpushbar,autometer sportcomp
Remember I had the same problem? Lets put some 275's in there this weekend and that will solve your problem.
Jordan
Big A, something is not right. I was seeing 28 psi's of boost with just the EZ. You should not need more than the EZ, i. e. , bigger injectors, to get above 19 psi's.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Mopar tonneau,Lund bug shield,PM tractor utility back up lights,Penda bed mat and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
Big A - Just as an FYI, I was only seeing 22 lbs of boost with the EZ cranked on it's most aggressive setting and the non adjustable elbow in place. It sounds like you may have a leak. We should meet up, and I'll help you out. When I first put my boost gauge in, I also had a leak. If you put the boost line into the side of the engine. . you really need to get that bolt tight (but don't over tighten it).
Call my cell...
Kev
I agree with you Bigsaint. I'm thinking I got a leak somewhere. I dont think it's the EZ. Maybe the new elbow?
Kevin, I'll call you later.
Big A
[This message has been edited by Big A (edited 04-04-2001). ]
Boost module or connection maybe?
'99 2500 ISB QC SLT (No Leather!), 4x4, 5sp w/McLeod, 4:10, BD-II, PE, PE-EZ, 4"exh. , Pac-Brake, A-Pillar gauge pod w/boost and pyro, Line-X, V-1, lights, siren, lic. plt. frame says "Diesel Fumes Make Me Horny!", and much more goofy stuff.
i too only got 20-22psi with just the ez. now with dd2's i can hit 31psi but it will fall off too about 28psi. some of you guys seem to have alot of boost compared to me. i wonder if different gauges make a difference?
jim
if it ain't broke fix it till it is!!
2001 eth, ez box, dd2's
My Ram Pics
TTT. Just wondering if you have it figured out yet ? If not, what source are you using for the boost and did you check that boost line to the gauge for kinks, twists, abrasions, etc. along with the fittings at the source and the gauge.
Scott W.
I am getting 27# with just the EZ boost elbow and no other mods( other than exaust). i see that same 27 no matter which setting the EZ is on. I have new Autolites.
01 2500HD QC,SB,3. 54,5 spd,4X4,241HD,SLT+,Sport all black,fully loaded,all leather htd,jacobs e-brake,tow pack,camper pack,,full rhino lining bed and rocker panels,265/75r16 BFG ATs ko,nerf bars,everthing black,4'' Jardine,ultra lite pyro & boost on a-pillar,EZ,NO stickers except cummins on door,License plate-1 CUMN, NRA endowment life member
I am getting spikes of 33 and continuous 29-30 with ez, non ajustable elbow and 275's. With just the ez, no elbow or injectors I was getting 22. The 22 was with the ez on setting 3 (out of the box) and 29-33 is with it on 2 I have not played with the jumper just turned it down with the addition of the injectors. Might go to setting 1 to be nice to the clutch.
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, BD Exhaust Brake, JRE 4" exhaust, EZ w/ elbow, 275's, SPA, Amsoil Dual Bypass Filter, Amsoil under the hood (soon to be everywhere else), Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
I talked with BIG A yesterday and he said that he got up inside of his hood and was fudging around... noticing that the bolts going to the side of the engine block were kinda loose. So he tightened them up.
Big A said that he'd call me today to let me know how this worked out. . but I am yet to hear from him. Guess I'll give him a call. I'll let you guys know what I find out.
Kev
The boost elbow must have a leak. I disconnected it from the waste gate,Plugged them both, and I'm seeing about 23pounds of boost without much problem. Thank all you fellas for the help. Taylor from Edge products was a lot of help. I'm glad I got my EZ from them.
Big A
