Competition Which DTT Converter will give me the quickest ET
Competition Want to et started in Pulling, need advice
Competition 278.5'...bang!!!
Originally posted by BillGotthelf
Ob1kobi- drag racing without using a lockup switch and the TC probably will never lockup as your foot is on the floor the whole way down the track. With a lockup switch the trans will lockup whenever you activate the switch (as long as you have some valve body mods for 2nd and 3rd gear). It will even force it to shift locked. Depending on your power level it will cut as much as 1 second off your 1/4 mile times.
hmmmm, mine locks up in third just before the 1/8 mile, and then in fourth just at the finish lights. I don't have a lock up switch, and drive it with both feet flat on the floor... . :)
I don't think my l/u switch is working. I let the truck roll in a parking lot and flipped the switch and the truck didn't try to cut out or anything. Then I flipped the switch and various speeds and gears and the rpms always dropped when I let off of it. Is there anything else I can do to find out if its working or not?
Brandon,
If the lockup switch is working the transmission wont downshift and if you try to stop the truck it will try to kill it. You either have to unlock it or put it in neutral to prevent it from trying to kill the truck.
Nathan
