This one stumped me. See my signature for upgrades.
Went to run some errands yesterday, and on startup, the truck stumbled and died immediately after the usual 3 engine rotations on initial crank.
Started the truck up again, a little puff of white smoke and all was good.
After the engine got to operating temps, I did a rev test (from idle to WOT - mashed the throttle). I got a second or so of stumbling, a bit of white smoke, then an arse load of black. Did it a couple more times with the same result. Now here is the kicker. I turned the comp box on (set at 1 X 1) and did another rev test. Ran fine, expected amount of black smoke (significantly less than with the box off) at first then cleared up and smooth.
I checked for codes and all I have is the usual 1693 and a 0236 (map voltage too high, too long).
I no longer have access to a scanner to observe the sensor downstream readings, so I don't know if my MAP is constantly showing high pressure, or even reading at all. Boost, fuel pressure and EGT's are all normal.
Otherwise the truck runs fine. I usually run with the comp box and water meth inject. off. I only turn them on when I want to play or EGT's are an issue (towing, hill climbing ~ EGT's 150* cooler with the Comp on driving in the mountains).
So, until I figure this one out, the Comp box stays on full time.
Opinions?
Opinions?
