I researched replacement batteries that will fit the tray and here are the facts:
Stock Battery:
Group 27, 750 CCA, 150-minute reserve capacity, 53 pounds.
Optima 34 or 34/78:
Red top, dark gray case “Starter battery”
800 CCA, 110-minute reserve capacity, 37 pounds.
Change from the stock battery: +50 CCA, -40 RC, -16 pounds
Optima 75/35:
720 CCA, 90-minute reserve capacity, 33 pounds.
Change from the stock battery: -30 CCA, -60 RC, -20 pounds
Optima D34 or D34/78:
Yellow top, light gray case “Deep cycle battery”
750 CCA, 120-minute reserve capacity, 43 pounds.
Change from the stock battery: 0 CCA, -30 RC, -10 pounds
Optima D31:
900 CCA, 155-minute reserve capacity, 60 pounds.
Change from the stock battery: +150 CCA, +5 RC, +7 pounds
Optima D31M:
Blue top, light gray case “Deep cycle battery”
Now here is my opinion:
With the exception of the last two, D31 batteries, the smaller Optima batteries do not have enough capacity to replace the stock battery under all conditions.
Cold Cranking Amps only matter when starting in cold weather or using a high current accessory like a winch.
Reserve Capacity only matters when running accessories with the engine off (radio, lights, trailer) or to allow operation with a failed charging system.
If DC could save money by using a smaller battery they would.
Stock Battery:
Optima 34 or 34/78:
Optima 75/35:
Optima D31:
Optima D31M:
