The Allisons are very strong and can take a lot of abuse. When I ran a quality and reliability test cell for Allisons, on some test I would put a load on the transmission so hard that the paint would burn off the converter, and the case would be hot enough to make drips of water sizzle. Drop the pan, change the fluid out, do some checks and fire it back up. Even the ones that I did manage to destroy would still pull a sizable load with new fluid and filter.
I know I tested a few that were used in the European truck races (medium duty big rig trucks) so that tells me they can handle any power we can muster up out of a 5. 9. I believe the trucks were seeing HP numbers well past the 1500 point.
You know how it is, want to play, gotta pay.
Always ready to help!
2000 2500 Red Sport quad cab, 4x4, K&N, DDI's, straight piped, boost, pyro and fuel pressure gages, Hot Power Edge, mean looking set of 33. 5" tires, Snap On diamond tool box, Marine Corps window sticker, Semper Fi!
1972 340 Cuda'. Original tripple Black, 340 car w/air. Good clean car, super stock springs, Weld Prostars, shaker hood, strong 340 with a 727/4000 stahl, 4. 56... . Bombs away!
NRA Life Member.
http://www.geocities.com/chadsheets
