The recent TDR has an article on guages. I would like other opinions and where I should go. I will also need a fuel pressure guage added along with the standard EGT,boost,temp.
Originally posted by AFacey
curatchko-
where did you get those guages?
Originally posted by curatchko
Hey I tried to get that steering column mount and it's been on back order... .
Do ya like it?
Hey curatchko-
I noticed that your boost guage only goes to 25 psi. Correct me if I'm wrong, but if you have at the very least an edge box and modifed wastegate - you should be seeing nearly 30 psi on the boost. You would need at least a guage that could display that right? I do believe from your sig you have those mods... what are your max boost readings?
