Wind Noise
Pacbrake compressor won't shut off...
Cab marker lights (82207252AB)
Since new, the drivers door seems to be the only door with excessive wind noise and no it's not just because it's the closest one to me. I thought I heard that there were no aftermarket seals that were better than stock but there was an adjustment that would close the door a little tighter. I looked today and I couldn't see anything to move. Am I hallucinating about the adjustment or just blind and can't see where to do it?
I have seen people actually tweak the upper front door/window frame in a little to quite the wind noise down considerably.
Due to the tearing of the weather stripping from the door opening on the 04/05 ML they changed to the 06 designed. My buddies has the same issue.
Mac:cool:
While under warrantee I had my torn weather stripping replaced. No issues so far.
I decided to leave mine torn. It doesnt seem to leak any, plus I heard the fix made some wind noise. This the first time I have heard from someone who had some good luck with the fix... .
Mac:cool:
For those who haven't yet torn the old design, consider lubricating the weatherstripping periodically with some silicone spray. My weatherstripping is 8 years old now and still not ripped - I credit silicone lubricant. A couple times a year is all that's necessary.
-Ryan
As stated, a very easy fix. I did mine this afternoon. It only took about 15 minutes and that included getting and putting away the tools and even vacuuming out a bunch of dirt. It does take a couple of good whacks to break the epoxy washer loose but that's all there is to the job. Thanks again TDR.
