window up/down control doesn't work
Hub Cover Modification
Factory Power Sliding Rear Window
On my '03 truck, the window up/down switch on the front passenger side no longer controls the passenger window. However, the switch on the driver's side still works. So, my wife has to ask me to roll her window up or down. I hope that I just need to replace the switch but don't know if it is an easy task. If not easy, then I need to get someone else to do the job. I only qualify to do the simple things.
Any ideas?
Glenn
Any ideas?
Glenn
Very easy to change, door panel doesn't even need to come off. Mine went bad to and had to replace the unit on the drivers side to fix the problem. Just lift the bezel up or slide bezel forward or backward just a hair and lift up, I did mine with my fingernails. Depending on where you purchase from:
Internet 80-90 bucks :), Dealer 120-140 #@$%!
Jake
Have you tried the rear windows?
If the rears go down then the trouble is most likely the passenger front door switch.
If the rears wont go down then either the window lock is on or the drivers master switch is bad. Either one pops out with a screw driver.
Maverick,
Your recommendation works... wiggling the passenger switch at the same time multi-pressing the window lock switch eventually engages the passenger switch. That said, I will be deassembling the drivers door switch unit this weekend to by-pass the lockout.
My rear passenger window won't work at times
Wouldn't you bet that the day I go to have my windows tinted it wouldn't work.
After slamming the door and turning the key on and off a couple times it started working enough so they could finish.
window lockout switch
Hi all; I have a 98 24 valve and it doesn't have a window lockout, but my 03 ]Durango does. The right passenger window wouldn't work and I thought it was the switch. It was the window lockout switch on the drivers side. The lockout switch will cut power to all windows but the driver when pushed down. If no green light in the other switch handles, then there is no power to them. This is what I did. Be advised that this is a delicate operation and if you undertake it you may be buying a whole new or used panel if you slip up. I am not responsible. Loosen door panel. disconnect handle arms. remove connectors. Remove switch panel from door panel. Remove screws from sw panel. You have to remove the caps off the window switches, including the lock out. Mirror caps stay on.
the sw covers should be heated like with a normal hair dryer to make them pliable, not too much. Use thin blade putty type knife to pry up one side. Reheat some and pry other side up and off. Don't crack the plastic, use finese, and easy steady pressure. The lock switch cover will probaly fly off.
remove screws on back of panel. To release the plactic lock tabs, use razor blades or similar to keep lock tabs released as you go. The lock switch has 2 tiny lock tabs on the cover. Use some thing tiny to release.
You now have to understand how this switch works(if it is the same as mine).
It has a square rod out the top and it has a strong spring under it. You must hold the case down as you release the 2 lock tabs. The inboard side has a y type spring on a round stud at the bottom. Look very carefully when you release the case how it is on and do this where you can't lose it, like cut out one side of a cardbord box. Sweep the floor if needed first. The outbord side has 2 verticle copper terimals on it. As the switch latches up, it completes the window power circuit and powers the other windows. When down, the 2 coppers are not connected and no power flows. I was not making contact in a steady matter. I bent the 2 verticle copper contacts in SLIGHTLY. so as to make steady contact. The y spring is the latching catch. As the switch moves down, the long end ((tips pointed to inside and long end up) moves up a ramp, settles into a pocket in middle in the latch down position. push down to release, spring end goes out of pocket and is ramped to release position. When reassembling use like door lube wax to hold spring and small screwdriver to hold spring loaded plunger as you ease the cover on and latch. Check operation of switch with ohm meter for proper operation. Be sure. I am going to silicon the switch covers for futurre removal. TO DO THIS, YOU MUST HAVE PATIENCE, DEXTERITY, SCHEMATIC. CONNECTOR PIN NUMBERS ETC. Remember, this was a durango. If you doubt your self, buy the panel,you may do it anyways. Plastic cracks easily. LOTS OF LUCK
