xcellerator hot version installed
posting video
Stanadynes fuel/water separator
They must be using a correction factor for naturally aspirated engines ,I am not sure but I belive it is differrent for turbo because at sea level or 29. 92 ' of mercury and 60 f we all are at 14. 7 psi or 1 bar. As you go up you loose a couple of p. s. i. for every 1000 feet or so. Hence the turbo you just add them write back. I read about this a while ago and will look up the exact numbers. But basically if you go up 5000 feet in elevation and loose 5 psi of atmosphere,all you have to do is add 5 psi boost and you are back to the same h. p. So in theory if our trucks were the same and I was at sea level running 50 psi and you were at 5000' and running 55 psi we would be making the same power and doing the same 1/4 mile etc...
yeah i plan on doing that once bandimere opens what are the times that a 600 hp truck should have and keep in mind when i run it all i'm doing is taking off the spare i'm leaving the grill guard and all that other stuff on it because i wanna know what it's gonna do on an average day. Drive it there of course trailering is pathetic in my book. Tow it to a spot to drive it that's ridiculous. I'll drive it on whatever fuel i have in the tank when i arrive
i don't have a clue about all that i just know that the numbers on 2 different dyno's were very similar that's good enough for me. If i make it to vegas this year i'll do one there and see how it is.
that's the best i can do though
I am sure they are right but all I was getting at is the observed number is the one to go by when dealing with turbocharged engines.
J. Davy said:
BCarmicle,what are you getting in a 1/4 mile?
I ran a 13. 51 on a single charger leaving the line at about 10lbs. of boost and running the 35" tires.
I have had very limited time to race with the twins. When weather warms back up I am going to do some testing with twins and try the stock tires and wheels.
Hoping the be at least in the high 12s.
Brandon
that is a good time that's what i'm shooting for middle 13's and hopefully ending up in the high twelves eventually but i don't know if i can get there with this elevation here
sure man where u at today i'm gonna be taking off here in a bit i can hook up with you if you want and let u check it out and if not then whenever man i'm readily available to look at and talk trucks. Seems like my whole day revolves around it anyway..... i might see if i can't get on the pfi dyno today actually since my last run was with the stock fuel system i figured now that i have the fass back in there it might be a bit more impressive maybe the 600 club
hook up
Hey that sounds great, I had to go out for awhile today, but any time on the week end will work for me. If you want to come by my place I can show you my "57" I don't take it out much this time of year. If this sounds good to you let me know andI will pm you directions and address. btw I am in S. W. Ft. Collins by Harmony and shields
sounds awesome i'd love to check that classic out sometime man i'm getting excited just thinking about it... ... man i'm right west of jj's past the trailers believe it or not lol
towards the reservoir... .
it's a shame how much water is in that lake or i should say isn't in it... . still nice country though
