Xenon lights flashing 3 times and shutting of
HID and DRL
Heater Blower Speed High speed only
Hello I installed a set of Xenon Pro lights and related wiring and capacitors ect. When I turned them on they worked ok then after I installed the Lights. I turned them back on it started flashing (3 times) so I pulled it back apart checked connections grounds voltages 12.8 took the anti-flicker capacitors out of the circuit same thing called their tech line and was told that my truck was rejecting the lights have no day time lights or automatic lights has anybody had this problem if so what fix or go to LED and where do I get LEDS
I pulled whole kit capacitors ballasts anti flicker capacitors bulbs after finding out that the total integrated power module has a printed circuit board which also feeds both right and left headlights. Bought a rebuilt circuit board 675.00 at Maks TIPM rebuilders already programed (TIPM Builders.com) installed LEDs 99.95 now have headlights lesson learned
