2nd Gen Non-Engine/Transmission 02>03 Track Bar Conversation;Problem?
Engine/Transmission (1994 - 1998) shut-off solenoid
Engine/Transmission (1998.5 - 2002) max flow power elbow
Installed the 03 Track bar conversion Bracket and 03 Bar in 02 4x4.
Drives GREAT!!!!! But I got a ' CLUNK'
When turning wheels hard from side to side ( like backing from driveway )
or 'not moving' I get a 'CLUNK'.
I have checked everything, nothing looks to be hitting.
Anyone else have this occur???
I had similar situation. Had a friend turn the wheel while I was underneath. Tracked down the noise more by feel than sound as I could barely hear it with the engine running underneath there. For me it turned out to be the pass side bolt. I am sure I had it torqued to spec but nonetheless cranked it just a bit more and no more noise in over 100k.
If it wasn't there before, like BarryG, I'd go over all the fasteners - first off have someone turn the steering wheel side to side as you lay under the front end and look at everything - make sure you also look at the sector shaft (comes out of the bottom of the steering box) for side to side deviation as it rotates.
Good info, I'll retorque the bolts,
Waiting for assistant ( wife ) too return from her mothers... .
Gotta getrrdne, hunting trip starts Mon, I hope... .
