Yo Hoot: The Borgenson arrived Tues aft. , but I opted for the $700 68170214AA Steering Box '03--'08, as it would only be an additional $200 & would not require "hand machining" flats on the boxs' input shaft. The install began today & went South in a hurry. The new pitman arm had a wierd twist in the end, which when mounted, caused it to contact the 'tie rod' attached to it. The technicians spent several hours of phone calls & research to yield Chrysler's advice from Engineering, that the entire steering linkage needs replacing to maintain proper geometry with this new Steer gear box! Now that's another $600! Tomorrow's another day. We'll take a fresh look at it then.
Remember I questioned what's heavy duty about it? Whew, it's a monster, 25% larger & the sector drive shaft is twice the 2004 diameter.
How is your replacement gear box install going?
