06 ball joint specs please
Installed S&B cold air intake
Fuel Guage not working
my 06 mega 4X4 has 20 th on the driver and 18 on the passenger side.
I am in warranty, just need to know what the dealer limit is so they can replace them. On the driver it started to eat the inside of the tire.
** they said last time at 14thousands that it was still in spec last fall.
TIA
jesse
Lower b/joint
LOWER BALL JOINT
To properly diagnose the lower ball joint two readings from the dial indicator are necessary, The two readings must be added together to find a total ball joint movement as identified in the steps below.
1. Raise and support the vehicle.
2. Attach a dial indicator (2) with the indicator resting on the flat part of the steering knuckle (1) by the lower ball stud .
3. Set the dial indicator (2) to zero.
NOTE: Use care not to damage the upper ball joint grease seal (3).
4. Pry between the knuckle (4) and the axle tube yoke next to the upper ball joint (2), Record the reading on the dial indicator. This will be the first reading.
5. Set the dial indicator (2) back to zero.
6. Set up a jackstand (3) and use a long prybar (1) to lift the knuckle assembly
7. Pry upwards on the flat part of the steering knuckle (5) next to the ball joint stud and nut (2) using the jackstand as leverage. Record the reading on the dial indicator. This will be the second reading.
8. Add the two reading together for a total lower ball joint movement, If this reading is above 2. 29 mm (0. 090 in) then replacement of the lower ball joint is necessary (Refer to 02 - Front Suspension/Front/BALL JOINT, Suspension - Removal) .
UPPER BALL JOINT
To properly diagnose the upper ball joint two readings from the dial indicator are necessary, The two readings must be added together to find a total ball joint movement as identified in the steps below.
2. Attach a dial indicator (3) with the indicator resting on either the front or back sides of the steering knuckle (4) as close to the upper ball joint (1) as possible .
3. Set the dial indicator(3) to zero.
4. Grab the tire by pushing in on the top of the tire and pulling out on the bottom of the tire. Record the reading on the dial indicator (3). This will be the first reading.
5. Set the dial indicator (3) back to zero.
6. Grab the tire by pulling in on the top of the tire and pushing out on the bottom of the tire. Record the reading on the dial indicator (3). This will be the second reading.
7. Add the two readings together for a total upper ball joint movement. If this reading is above 1. 52 mm (0. 060 in) then replacement of the upper ball joint is necessary (Refer to 02 - Front Suspension/Front/BALL JOINT, Suspension - Removal) .
