I have a 2001 Dually 4x4 Quad Cab pick-up. I live in CA and when the truck was new I could only go 60 mph floored towing a 10,000 pound tag trailer on a flat open highway. I went to May Madness in Las Vegas hoping to find answers. The truck has 4:10 gears. I ended up at Diesel Dynamics. They dynoed the truck and found 205 hp. They suggested a Edge Easy Box. Instead I got the Edge Comp Box. They told me I had to put a DTT converter and valvebody in it. I bought these items and installed them.
I then took my trailer on a trip. I had the box on setting 1 smoke level 3. As I went up a steep climb I ended up going about 30 mph in second gear. Boost 30, trans temp, 290, EGT 1300, Engine temp 240. I shut the box off with no improvement.
When I got home I called Bill Kondolay he told me to get Synthetic ATF. I now have Synthetic ATF. I also called Diesel Dynamics. They told me I needed an HX40 and 4 inch exhaust. I drove to Las Vegas (12 hours) to get this done so I could see thde Dyno results. While there I asked them what else I needed to have the most powerful reliable towing rig. They suggested stage 2 injectors. I now have 306. 7 horse and 602 torque with the box off. Box on setting 5 I have 433 horse and 846 torque All rear wheel measurements.
Last weekend I took my trailer out. Going up a grade in 37 degree outside weather with the box off my EGTs would easily go 1400, trans 280, water temp 240. I never heard the fan clutch lockup though.
I need help. I built this to tow, but am having lots of problems. Any ideas are appreciated. I have more story if more info helps. I tested the thermostat on the stove. It opens full at 190 degrees. the pressure cap is good too.
