2001 Truck problems?
Any problems with your 2001 truck?
  • No problems - it's perfect!
    Votes: 58 38.9%
  • Trivial - fixed easily.
    Votes: 62 41.6%
  • Noteworthy - Took at least two trips to fix it properly.
    Votes: 19 12.8%
  • Onerous - Had to argue more than once.
    Votes: 3 2.0%
  • Contentious - We don't agree there's a problem.
    Votes: 4 2.7%
  • Engine - Dealer repaired.
    Votes: 3 2.0%
  • Engine - Cummins repaired.
    Votes: 0 0.0%
  • Engine - We don't agree there's a problem.
    Votes: 0 0.0%
  • Total voters
    149
Screens & Intercooler Efficiency
Fuel filter change intervall?
56,000 miles on it now
Have had two failed lift pumps so far,a leaking tailshaft seal, and now a power steering leak that I haven't had time to take a look at. Should be a straightforward repair... .
No other problems at all.....
Zip, nothing, nada, it hasn't even hiccuped!!!!!
At 28K it is perfect, and that inludes three 3000 mile trips grossing over 19K.
(except for that "flapping" noise.
Vaughn
Just the ignition steering key/lock/barrel assembly on the steering column, that kept jamming and wouldn't let the key turn on, fixed under warranty. and everything's been as good as gold since.
Close to 30,000 miles in 14 months. Dealer fixed a leaking pinion seal at about 7500 miles, other than that it has been better than snuff as they say. 21. mpg the road.
Musclefixer
I usually tell them "Maybe if you feed your truck the right stuff, maybe it'll grow up to be a truck like this".
As far as problems (2)
1. Defective throttle postion sensor
2. Broken clock spring
Other than that, I wouldn't have it any other way.
John Styer:cool:
