After many moons of procrastinating, I finally got my IssPro 30 PSI mechanical fuel pressure gauge rigged on the 2003 HO. Install was reasonably easy. Just popped out the fuel supply banjo on the fuel injection pump, and threw in a tapped banjo with an elbow, a stainless line and away we went.
First impression is that the noise is considerably higher than a direct connection to a VP44. I may try snubbing it down, but I think I'll move the tapped bolt back to the filter canister next weekend and see how it affects noise and pressures.
And the fuel pressures:
Idle - 9 - 9. 5 PSI
Cruise at 60 mph - 8 PSI
WOT - 5 PSI
And after talking to a few developers who are testing out their prototype fueling boxes, its been discovered the new lift pump is every bit as weak as the old one. Possibly even more so :{ For all you guys installing gauges, make a fuel pressure gauge part of the package...
Idle - 9 - 9. 5 PSI
WOT - 5 PSI
