That is adding injury to a big helping of insult! Wow, that's a bad time.
Update from Friday, they stacked the aftermarket and DMF assemblies next to each other. The OEM setup measure 1/2" taller to the disc center and fingers than the aftermarket flywheel and pressure plate. The added distance to the plate would explain why the bearing retainer contacted the clutch plate when first assembled. Sounds like the customer is really ****** as the truck has been down a couple of months now.
Also found out the truck was purchased used at auction and the engine serial number matches the VIN of the truck. One theory was there were two possible engines for this MY, but looks like the truck has the OEM engine.
So there is more to the story but we just have not learned it yet. My advise was just replace the AM clutch with another and call it a day.
thumpathumpathumpa.......
Have you been studying how to speak Mainer???? I'm getting a little weepy 'cause I'm so proud of you for tackling a foreign language ......![]()
