I'm still working out the bugs--I pegged 71psi on the dyno and the temps were 1387 with my original B1 and Big Brother and Bullydog 11 injectors--so that part is awesome, but I couldn't get them to light at the Bullydog sled pull--I'm not sure if it's a turbo issue, altitude issue, too tight of a torque convertor or something else at this point---truck does seem to run hotter for everyday driving with the drag comp set on 1 or 2(outside air temp 70-95, cruising at 70mph, 2000rpms, 9psi boost temps are 1140ish)(with box off and outside temps at 60-75 egts were 950ish), but I'm going to get the air filter up on the wheel well and that may help the running hotter issue some, but the spooling issue is the major issue at this point--the everyday temps are the same if I use my original B1 or the B1 on steroids--I took the B1 on steroids off for the drive to Idaho hoping the egt temps would change, but it didn't--didn't have time to get the B1 on steroids back on to dyno and pull with, so further testing will have to be done in the future with the steroided B1--- egt's didn't care if I used Bullydog 8's(drive to Idaho) or Bullydog 5's drive back to CA)----I did try to spool the turbos last night, but she gets to about 1500rpms and then doesn't move--boost is between 3-4psi--this is with the box set at 5--I am going to see what happens with the box off and that will tell me that it's not an altitude issue and something else----chris
