2500 w/10K 34' Trailer Opinoins
Which Controller
Weight Over Rear Wheels
I am looking for comments about pulling a 10,000 lb travel trailer gvwr with a 2500 QC/SB 4x4. Is that to much weight or more problems than it is worth? Even though Dodge says 13050 lb max towing weight. Thanks.
By TT assume you mean a bumper pull. No problem with the truck as long as you get a WD hitch. The trailer weight is no problem with a stock motor and transmission, but you don't list any mods.
It really depends on how well balanced the TT is. I had a 9K 31' front kitchen before the fiver. I would never have another front heavy TT. I pulled a 38' TT for a friend several times that pulled much better but it was a center kitchen with slide and also had a rear bedroom slide making it much lighter on the hitch.
It took as much air in my bags to level my TT as it does to level my fiver with 2700# pin wgt.
