I've been hunting decent sized ATF leaks, but I can't pin point the driver's side leak on the trans. It sprays ATF on the driver's side up to the shift linkage and then its dry, I watch it underneath while its in gear or neutral hot or cold, doesn't leak. I guess its only leaking while driving, maybe just at a load. But it leaks enough to drip and get the pan soaking wet collecting dirt and making a muddy mess. I cleaned and dried it today again with brake cleaner and can't get it to leak at home.
I will keep trying to find it, but the only thing I can think of is the sensor right above the pan, the park/neutral sensor. It does get soaked, the temp sensor not so much to the front. It sprays enough on the shift linkage to make it drip off the arm/pivot point. I'm guessing its spraying up from that horizontal sensor. Do those fail commonly? Never had any leaks like this before, usually its a pin hole in a cooler line. I had a cooler line leak at the fitting that I could tighten, my bell housing seems to stay dry after tightening the fitting below the water exchange thing on the engine. I hate leaks that drip ATF!
I guess I'll try replacing the sensor or maybe make a gasket for it, I think the temp sensor is not leaking but, its hard to say. Is there any other common leak sources around the linkage?
