JeepBuilder
I have owned the truck 3 months. I know some day some where I will finish the up keep and not have a long list of fix it stuff to think about. Well today the list got a little longer. It's an 01 DRW 3500 turbo diesel with the much loved NV4500. I have been having trouble with the clutch lately not disengaging all the way. It was getting tough to go into 1st and reverse had mild grinding with a pretty good lurch once it landed in gear. That told me it was getting a tad bit of drive causing the truck to bump. I know the previous owner. He told me it was a southbend dual disc clutch. And it is I found. Last weekend I changed out the hydraulics and no real improvement. I discovered by viewing Southbends site that I had removed their big 1.75 hydraulic set up. The master was damp around the push rod boot. I noticed the clutch fork was only about a 1/4 inch inside the bell housing window. The guy at SB said it should be 1/2 to 3/4 in. So deciding to go back to a single heavy duty disc clutch, I took everything out today. The trans was low on oil. No idea if it was the correct oil. When I took off the adapter I reached up and grabbed 5th gear. To my dismay it rocked back and forth a very slight amount. Probably somewhere around .050-.060 backlash. I saw the nut had a torx head screw and the nut was slotted. I loosened the set screw and got close to a full turn with the correct nut wrench from Torque King and a 4 foot bar.
I also purchased the 5th gear repair chromoly part that locks the nut using the splines on the shaft. It engages the slotted nut and shaft splines and looks to be the best solution for keeping the nut tight.
The gear is tight now from tightening the nut, but I am fooling myself thinking it will hold right?
I should probably bite the master rebuild kit bullet and get the fully splined shaft and gear and just do the rebuild? I have everything to do it here and have experience with gear boxes, but I am super leary of the imported parts in the kits. The transmission has 164K on it. I would prefer to do the rebuild myself verses sending it out to be done. The original 5th gear nut does not have the slot with a torx head screw right? Someone else put that in?
And I am wondering if Torque King's kits are the same as every other one out there. Their prices are pretty high compared to others like Standard I have used them for NP205 rebuilds but never for the NV4500. Are their parts really better? Or just more expensive? I would like to find the highest quality kit I can. Any suggestions or input?
