I took out the #10 plate I had, and installed the #6 plate I just got. I think the truck has a little bit better power, but I still don't think it's giving me what it should.
Boost and EGT gauges installed.
New fuel filter. Air filter recently cleaned.
Intend on replacing the strainer on the fuel heater but haven't done that yet.
Truck currently has 1/2 B100 Biodiesel and 1/2 #2 Diesel. But I've been running it like that for a while. Only difference between this and all #2 is the lovely smell the B100 gives.
Climbing a fairly steep grade on i80 crossing over to the Sacramento Valley, on cruise control at 75mph the truck is climbing better than if I put my foot down. Hmmm. EGT climbs up to 1100 degrees, and Boost is just under 20lbs. That sound right for an empty 4x4 truck? What is expected range for boost? On the freeway at 55-60mph EGT is around 600 degrees, and boost something like 4 -5 pounds.
No smoke under heavy acceleration. Star wheel moved forward about three turns from stock.
Throttle cable seems kind loose to me. Also, at the throttle pedal, if I lift up on the pedal this generates about 1 1/2" of cable play at the pedal. Reason I'm thinking about this is that the truck seems to accelerate better with cruise control than my foot. I know these cables had a recall, and this particular truck did have that cable replaced, but that's been several years.
Have built a boost pressure tester but haven't used it yet.
This is my first 12v Dodge and I really don't have a benchmark of what the stock power should be and what a #6 plate feels like. With the #6 plate my Dakota with 4. 7 liter V-8 would run circles around it. Heck I think my wife's Honda Element would run circles around it.
I appreciate any feedback.
GulDam
GulDam
