OK all you oil gurus, here's one for ya.
Just installed a McLeod duel disk street version clutch in my 01 ETH about 2000 mile ago.
With the truck idling at a stand still, in neutral with the clutch engaged (clutch petal out) there’s a rather LOUD grinding noise coming from the transmission.
I love this clutch except for the "neutral grind".
According to expert opinion the neutral grind is caused by the duel disk clutch not having springs (un-sprung hub) therefore causing the engine pulses or harmonics to travel through to the transmission gears. Apparently clutch springs act as a vibration dampener. When the clutch is disengaged (clutch petal pushed in) the noise goes away. The warmer the transmission oil gets the louder
the noise gets. The noise is so loud, when I pull up to a group of people with the clutch disengaged and then put it in neutral and let out the clutch people say "What’s that noise
. I wouldn’t mind so much except for the fact that I really like the sound of my Cummins purrrring
and the neutral grind is almost as loud as my precious Cummins
I just replaced the OEM oil with some Amsoil 5-30 and added 8 oz of Lucas oil additive and still no help
So, how about it guys. Any suggestions
2001 Driftwood 3500 Quad Cab 4x4, Long Bed, 5. 9L HO Cummins Diesel (ETH), 6-Speed HD Manual (DEE) Loven the shift thing (Arrrrrh), 3:54, SLT+, 3. 54 Anti-Spin Axle, Camper Special Group, Trailer Tow Group, 18,000 LB 5th Wheel Hitch, Leather, Sliding Rear Window, BDs E-Brake, Rhino Liner (gray), Velvet ride shackles, cup smoothy, Power Edge box / EZ Box w/elbo, DD Stage III injectors, McLeod Dual Disk Clutch, K&N, SPA Gauges, Jardine Exhaust, 16cm turbo housing. Love the smell of diesel in the morning. Hope your watchen DC cuz every thing you see here is a big lie, Hehe.
