This is very frustrating ,checked all wiring under hood all seems well, tightened all grounds rechecked all fuses , unplugged three big wire plugs at the computer behind the air cleaner on the firewall, and it still runs ??? i used a feeler gauge and set crank pos sensor @ .050 ,there is 3 wires from the harness that plug into cps center wire was hot, end one hot but dim, other side nothing, all tested with test light grounded on battery - negative, took it for a ride and notice that the speedometer, i did not notice it when this all started, tach, a/c ,and tps, nothing working do you think its the computer? help.....and thanks
