a bunch of questions?
Update on sagging Kore coils
Cummins B20 update
First I am gonna be in need of a new exhaust my factory unit is about done tail pipe is going to rot through. I want something quite any recomendations besides factory replacement? Anyone using Corsa exhaust? Second Im gonna need some new front brake pads will the dealer ones last as long as original? any one using performance friction pads? or some other that have worked well and lasted a long time?
and: Can i check injectors by unpluging them to see if the noise goes away or is that not a good idea?
and: Anyone have any bad experiences with Dunrite converters and trannies?
and: I capped the vents on top of the fuel tank Good or bad idea? Had no line at the time.
see i told u alot of questions.
Dan
Unplugging the inj will cause a code of course, other than that I dont know what else could happen.
As far as the vent thing, mine was plugged by the factory and hasn't caused any problems.
Scotty
