Engine/Transmission (1998.5 - 2002) A few questions?
2nd Gen Non-Engine/Transmission Innovation Camper Shell
Engine/Transmission (1998.5 - 2002) how do injectors match up
Hi all, Ive read alot of threads on the edge and tst, and still don't know what to get a little help please, also do you have to do the wire tap to get the 120hp? and what does that do? and is IT bad for the VP and the LP ? also are they hard to put on?
one more question I called and got a fuel gauge on order(turbo tim will be happy) and a max hi flow kit just wondering how hard the fuel gauge is to put on? I know this has been gone over and over so please don't flame me, thank you:) :)
I think I am correct in saying that the TST will give you more torque than any other box and be about the same on HP. The TST with gauges can also be set to defuel at a user defined EGT. Yes you will have to tap the pump wire to get the 120 HP. Will you have problems? some do, most don't. After tapping my wire it was fine for a few months and then I started to get stumbling problems and engine light coming on. The pump wire was tapped with a scotch lock connector, bad idea. I took it off and soldered the connection and everything is fine now. If you want the performance just do it.
Paul
