ABS pump repairable or must be replaced
MOPAR Accessory Towing Mirror Help
Add power mirrors to an ST truck?
SDrake
Just discovered that some of the spades in the 14 pin connector on top of the ABS pump/controller are toast. That connector is hard mounted on the controller and I don't know if it can be replaced or if it can be removed and repaired. I fear I am about to have to learn how to replace a pump. Never dont that.
Any one had one of these things apart. Can it be repaired with a replacement part? If not is replacing this pump a DIY project or am I doomed to go to Dodge dealer for this?
I have done all sorts of brake jobs and repairs but never got into replacing the ABS. I understand you have to be hooked to some sort of scanner to bleed it. It also probably has to be told some vehicle parameters or am I just punchy from reading so much about my truck?
