Aftermarket wheels that dont stick out
Need exhaust brake help.
Need help locating front bumper inserts
Does anyone know of an aftermarket wheel that is the same size as factory, the offset and size. I have factory suspension so I also dont want the tires to rub. I am looking for new wheels and tires that dont stick out too far. My wheel is a 16 x 7. 5. I am looking to put some cooper ST 285/75/16 tires. If anyone has info I'd appreciate it.
I think you mean 16 X 6. 5 width on you OEM wheel.
You won't find an aftermarket wheel with the OEM back space and offset. I tried.
LT245/75/R16 & LT255/85R16 will work on your OEM wheel.
You could try to find a set of Aluminum wheels off of a 2000-2002 2500 Ram. These are 8" wide w/ a 6 3/4" backspace. These will sit inside the wheel well. Might need to do a little work to get them to fit.
More wheel info: http://dodgeram.org/tech/specs/wheel/specs.htm
