Air Dam (important?)
Does this truck belong to a TDR member?
the headaches of summer towing
Hi guys
I know why the air dam is there but how important is it to have one while towing?
Mac B
01 2500 Bright silver QC A/T 4x4 LB 3. 54
I don't think they do anything at all!! I have all mine in the garage. Some may claim they help with milage or they direct more air into the grill but with a 7500lbs truck whats a little piece of plastic going to help!!! #ad
Pete
I had one on the 98. The 01 does not have it,other than looks I can't tell any difference.
2001 quadcab slt 2500 HO 6spd. LWB,2wd,dk garnett red, trailer tow package,camper special, anti spin 3. 54 axle, speed liner,oversized stainless steel chicken slide,66 gallon in bed aux. tank,K&N air filter,Reese 20k hitch, Terry 2000 EX 30ft. double slide 5er, 2000 20ft gooseneck for haulin jeep, firewood and huntin stuff. 5X12 tagalong for haulin the 4 wheeler. Okie Newton
Thank you guys
Thats what i wanted to know. If i would of ordered my truck i would of got one but i didn,t this time. just saved a few bucks.
Thanks again
Mac B
Theory is, one PROPERLY applied will direct air movement in a way that will benefit a vehicle in one manner or another - the FACT that ALL professional race cars use them pretty well proves their usefullnes IF they are installed correctly.
In the case of my '91 Dodge/Cummins (see pointer in sig below), I installed an aftermarket air dam below the bumper of my truck intended to increase frontal air pressure thru the radiator, while at the same time, provide a low-pressure area BEHIND the air dam to additionally promote air flow thru the radiator area. No way of knowing or proving the effectiveness of my use of the air dam - but I did manage to keep my coolent temperature within usable ranges in the older, poorly designed cooling system on my truck until I finally upgraded to a later and larger radiator.
http://community. webshots.com/user/davison71 Early '91 250, 727 AT, 307 rear... Banks Stinger exhaust, intercooler... US Gear OD... Tweaked pump, upgraded radiator... MORE than a match for every new PS Ford encountered so far...
"Dura" WHAT? NOW I know where all those recycled beer cans go...
I did not get one this time. had one on my 98. 5 gasser but I think the trucks look better with out. Can't find any reason to have one.
2001. 5 2500, quad cab, 4X4, ETH/DEE, 4. 10 LSD, 255/85 BFG MT, BD Exhaust Brake, JRE 4" exhaust, EZ w/ elbow, 275's, SPA, Amsoil Dual Bypass Filter, Amsoil under the hood (soon to be everywhere else), Leer topper, Piaa driving 510's in bumper, Line-X, Stereo= JVC KD-MX3000, MBQuart 6. 5 components in front doors, 6. 5 coax in rear, JL Audio Stealth Box sub in center seat, Fosgate 400a4 and 250a2 amps, DynaMat everywhere
the air dam doesent matter for most 4x4's, It 's a ground effects kinda thing #ad
but for a 4x4 it might help let you know if you're running over something potentially to tall #ad
on us 2x's the front end is lower and the aero feature can be a plus #ad
Besides gary I ain't seen one on those racing peterbuilts #ad
*Won Ton* 01 3500 eth 6spd- ez, pacbrake, ultra boards, pace edwards roll cover, rbw little rocker, rhino liner
*Pull Toys* y2k Cardinal 29rlb-lx, 175w solar panels, 1. 5kw trace inverter, dish net sat
i agree with gary concerning the "low pressure area" behind the air dam... can't remember where i found the info though... tom
2001QC 2500HD LB ETH/DEE 4x4 4:10's LSD, Pacbrake,Combo Gauge on A pillar,All options except cab lights,Xcelerator air filter,Forest Green/Light driftwood. Westin tubular black powder-coated side bars. Husky 16k 5th wheel hitch,26' Holiday Rambler 5th wheel,Extra Class Amateur Radio Operator ke3rx.
