Originally posted by Hammer
Well like I said before Don,you have crossed the line,,That line,like it or not,is the one that separates reality and your own little world you occupy,,One would only have to say the only reason you are continuing here is to pad your own post totals,but,I believe myself its your own way to try and hide a mistake you made and will not admit it,,See when you read thru all your"internet research" and get to the bottom line,you have a hard time admiting you made a mistake somewhere else and it has caused some of the problems you are claiming here that this "oil" caused,,Sloppy work and lack of research can and will lead to problems like you have now(i. e. -oil leaks,low power numbers for the money spent)and your poor attitude with these "oil" users and their"product",,It makes no difference to you that your continued bashing has left you all alone and with no other info to back up your claim(or your problems) and talking in circles so much you do not even know what you have said,,IF and I'll say it AGAIN,If this "oil" has you so up in arms WHY USE IT???,,Just because we(other users)do not have the "test" info you seek to please you,but,rather would rely on our real world tests for our opinions you look down upon us like trailer park trash,,I have seen the benefits first hand on its("the oil") protection first hand and all you can do is try to refute it with computer research and bogus info I care nothing about,,While you claim to "defend''the "stock"owners all I can see is your continued blinding of them by not allowing them to see both sides of the story,you only want them to see your side and flame the others that try to point out your incorrect data,,All you can do then is come back to the "not api" certified data and Since the majority of these owners here are not stock and could give a rats rear about warranty I'd bet that "not api" certified will not matter to them either,just plain old good protection,,A few other things and I'll leave so I do not to your post total either,,A few hundred posts earlier you said about your transfer case leaking and your going back to "dino oil" well my son that there IS a violiation of factory warranty,see,it has Mopar +3 in it WHICH is synthetic,from the factory,,So what is it Don,you sure you want to stand by the "oil" causing the leak or could it be normal wear or excessive abuse and temps????,,Also,If your so harsh on this product and it problems ARE YOU GOING TO DO THIS LATER IN MORE DEPTH FOR THOSE PRODUCTS AND VENDORS THAT CAUSED THE MEARE 400 HP YOU PUT OUT at a recent dyno meet??,,See a HEAVILY fueled truck should make more smack than that,your combo to me seems more off than you'll admit and could this be the cause of the "mysterious" leaks you complain about??,,There are more than a few owners that have made near what your "heavily fueled" combo made power wise in a properly setup stock configuration,,WHAT,you don't believe me cause it not on paper,afraid to say they are and the owners have showed it here and other boards that they frequent,,Seems like over 335hp with stock parts was quoted and NO AFTERMARKET equipment,,Again,research,not squabbleing,about products will get the help and power you seek,,Expensive parts may help but in some cases are not needed,just some dyno time with the combo(be it engine or chassis time),,Extended drain intervals as others have said is a owners decision and not for you to dictate,let them do their proper anyalsis and decide what road to go down,,Bottom line is this... IF YOU DO NOT LIKE IT. DON'T USE IT... ... If you'd ever like to see one of our race pieces after a normal maintence teardown,I'd welcome you come up and look them over I have nothing to hide,,I'd even set it up so you could pull her from the frame rails after a Friday,Saturday and Sunday weekend of hard work and let you do your own research on it,,I will not even touch a wrench,matter of fact I'll sit in a chair and watch you so I do not interfere with your fact finding mission,,Balls in your court pal,those have offered to help you and you refuse and those offer to allow you "real world proof' of the product,you decide,,Till then,don't waste our time... ...
