Amsoil Diesel Fuel Additive & Stanadne
Full Time Fuel Pressure Gauge
PDQ chip
Amsoilman: What Diesel Fuel Additive should be used in the 99 Dodge Ram, Cummins? Also I understand that the diesel pump manufacturer has Stanadye formulate the pump additive for the diesel pump. Is Amsoil above Stanadyne specs like they are on everything else?
Eino,
Amsoil does make two different Diesel fuel additives. I use the "Concentrate". It comes in a 16 oz. can and will treat 100 gallons, so I usually add 1/4 can each fill.
Have used it since day one, and now have over 100 K miles.
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
Wayne,
I was told not to use the Amsoil concentrate if my 99 diesel has a catalytic converter. My dealer says it does. So should I use the diesel modifier instead? Also my fuel supplier (Pacific Pride) uses Shaeffer diesel fuel additive at the pump. So now I feel like I would be wasting my money if I add any other additive?
Eino, Your 1999 Cummins ISB doesn't have a catalytic convertor. Go to The official Cummins web page and you'll see for yourself. If you look under your truck you'll see a small thing in front of your muffler, but it's a resonator---not a cat. Sam
1999 Dodge Laramie SLT QC, 24V Cummins turbo diesel ISB, 2WD, auto trans, 3. 55 rear end- LSD, long bed, HD towing and camper pkg,K&N air filter, CD player, electric seats, bright white, chrome diamond plate tool box, resonator removed, turbo silencer ring removed, all options except leather seats. "I love the smell of diesel in the morning. "
Hemet, California
Eino,
A couple of years back, there was a chemical in the Amsoil "Concentrate" that was considered bad for catalitic converters, so it was advised not to use it in a Diesel if it had a cat.
The chemical used in the "concentrate" has now been removed, and it CAN be used in Diesel engines that have a cat.
Diesel "Modifier" does not treat as many gallons, and is recommended primaraly for automotive applications(cars)
Wayne
amsoilman
Thanks Wayne,
I've used the diesel concentrate mixed with the cetane booster 50-50 in a small Ford Diesel Tractor for 5 years and it flat out cuts the smoke. Now I know I can use it in my 99 Ram, however Pacific Pride uses Shaeffer in their storage tanks so would I be wasting my money to use the Amsoil Concentrate? I was thinking of using it anyway but just using less. What do you think? Thank ypu!
99 QC Diesel,5spd, white,Laverne SS step bars, Mopar long mud flaps, A. R. E. cap with walk thru door, SS rock side panels, JC Whitney front bumper 14" guards,and BED RUG box liner.
Eino,
If pacific Pride indeed puts in the Shaeffer additive, you would most likely be going overboard.
I know however, here in Utah, we have several oil refineries, and I have been through a couple of them(benefit of being a School bus driver)on tours. The ones I did go through did say they put in an additive during the colder months, but each used a different product, and one could not tell me the name of it. Makes me wonder?
I do use the "Concentrate" year round in my 94 Ram. Just want the feeling of satisfaction knowing I am using what I consider the best.
Wayne
amsoilman
I am also an Amsoil user and dealer and swear by the stuff I don't use it as much as the amsoilman and I don't have as many miles on my truck as he does, I have 47k. I use the concentrate also year round, not as much in the warmer months but pretty religously in the colder months.
RamNProwler
Ed Council
Lake Stevens, Washington
1996 Black 2500 SLT CC, Atuo, 4. 10 LSD, Banks Power Pack, BD Torque Loc, Converter and Brake, Pyro , Boost and Trans Temp, Ultra Wheels, 28575R16 RVT Wild Country TIres, TekStyle Tonneau Cover, Lighted Sun Visor, Power Vision Mirrors, Spray in Diamond Liner, Diamond Plate Rail Caps,Amsoil throughout
LOVE THE POWER
Pull 27' Prowler TT all over Washington
amsoilman, how often should I use the Cetane boost additive. I live in S. Georgia, so I am really not as worried about cold weather as you guys up north are. My major reasoning behind using the treatment is lubricity to the fuel pump and power. I ordered a can of the stuff from a dealer who is a friend, so I could evaluate the performance. I put the stuff in last night and I would swear the truck ran better this morning, but that could just be perception. Thanks for any info
John
1999 Dodge Ram 3500 Quad Cab 5 spd; 4:10 LSD rear; Mag-Hytec diff. cover; US Gear EGT and Boost gauges.
Cummins Whup Ass, don't leave home without it
John,
Amsoilman might disagree with my thoughts. . But other than dealing with a really foul smelling additive... I didn't see any benefit to the Cetane boost. To me its a waste of money. I do however like the Modifier.
Course, if he does disagree, I'd like to hear why. . I'm always open for suggestions.
98. 5' 24v 2500 Auto/3. 54 4x4 SB QC 285-75-16's on Alcoa's. Everything but leather. PIAA 1200's, AMSOIL dual filter relocation system, Smittybuilt Stainless Steel Nerfs, Rhino Liner(Junk), K&N air filter(For Sale)15 year AMSOIL dealer. Time permitting, Soon to include Ultra-lite Pyro,0-50lbs boost, Trans temp in the pillar. Rancho 9000's with in cab adjustment.
