Amsoil OIL FILTER NUMBERS
Lotek A-Pillar
Product idea: turbo cooldown sense via trip computer
I use the amsoil filter #'s BE-100 and SDF 26 . Are there any other sources for thses filters besides amsoil ?? My fram book lists some Amsoil equivalents but none for these part numbers .
Click on this link: http://www.syntheticlubes.com/ofrefer.html
bill, I personally wouldn`t use any of the oil filters in the chart, on my truck. If you want the best Full Flow filter. . You want a Fleetguard Microglass or Stratapore, Depending on what year truck you have. Click on this link to see them:
http://www.genosgarage.com/acb/showprod. cfm?&D ID=10&User_ID=16810&st=8306&st2=-353093340&st3=333015814&CATID=1&ObjectGroup_ID=13
Bill R
94 2500 SLT,4X4,5 Speed,3. 54 LSD... . Still looks brand new... .
[This message has been edited by HEMI®Dart (edited 03-26-2000). ]
Billp,
You will not find any other oil filter that will replace the BE-100 filter. It is designed only to fit the Amsoil remote by-pass mounts. The SDF-26 can be replaced with any other OEM filter that will fit the Dodge/Cummins engine.
Wayne
amsoilman
94'SLT 4X4 AT/White in color. Factory Tow Hooks & Running Boards. Amsoil By-Pass filter, Amsoil Air cleaner,and all fluids are Amsoil. Optima "Red Top" batteries.
BD exhaust Brake, BD Torque Lock, BD Torque Converter, Dr. Performance Stage II Injection Pump. Mag-Hytec Diff Cover,Mag-Hytec Transmission Pan, Isspro Pyro, Boost,Oil temp Gauges mounted in 3 Gauge post mount. One gauge monitors Engine Oil, Trans, Diff. Temps.
