Here is an article I obtained back in 1998 regarding By-Pass oil filters. It was found in a "Fleet Equipment" Magazine.
Title: Don't Bypass Bypass Filters
Author: Gelinas, Tom
Journal: Fleet Equipment Vol: 14 Iss: 7
Date: Jul 1988 pp. 39-41 Abstract:
(QUOTE) According to some estimates, 60% of the potential causes of engine wear and failure can be eliminated by a well-designed and properly applied filtration system. Cummins Engine Co. recommends that both a bypass filter and a full-flow filter be used.
A bypass filter shunts 10% of the total oil pump output through a filter and then back to the sump, bypassing the engine. Because this filter has high-pressure differential and low flow rate, it can filter out fine particles in the 5-micron range. In contrast, a full- flow filter has a low-pressure differential and filters out only large particles in the 40 micron to 60 micron range. However, the full-flow filter is located so that all of the oil must flow through it before reaching the bearings.
The combination of these 2 filter types gives double protection against wear. Studies at the Cummins Technical Center indicate that wear can be reduced up to 91% by using a bypass filter in combination with a full-flow filter! (end QUOTE)
I am my own warranty station, but a By-pass oil system WILL NOT VOID A WARRANTY! Chrysler tried that back in 1983 when Amsoil came out with their By-pass system. Chrysler was "shot down" in court!
Wayne
amsoilman
