Mike,
Thanks for the speedy come back.
Regarding which Williams Controls part number to buy, here's my take on it after carefully studying their
catalog last night...
The Williams APPS "kit" p. n. 132034 does indeed include the APPS we need and the wiring harness, *but* it also includes several other items we don't need for a straight OEM APPS swap and it costs $149. 55 (
on the Williams Control web site). P. n.
131973 contains only the APPS and some screws, so you still need wiring harness p. n.
131165, but those two items added together costs less at only $120. 95, so that seems like the better way to go. But certainly buying p. n. 132034 is an acceptable alternative, albeit a bit more expensive.
OK, there's where you have me confused.
Unless I'm mistaken in my studies of the pictures in this thread and the Williams Controls catalog, the Williams APPS has a recepticle on it that the Williams wiring harness plugs into. Put another way, the Williams APPS is not hard wired. Please keep in mind I've never seen a Williams APPS in person. Now assuming you've modified a Williams wiring harness to connect from the Williams APPS directly to the stock (unmodified in any way) engine wiring harness but clipping off the supplied Weatherpack connectors and instaling a single Deutsch 6-pin connector in its place, why would you need a seperate "jumper" harness and have any problem reinstalling either an OEM or Williams APPS in the future?
This is the part I wasn't clear on.
Questions:
1. Is there a way to make this idle voltage adjustment you described on the bench using an Ohm meter? Could I adjust for lowest resistance and then back off the internal stop as you did?
2. Can you please reconfirm these are the wiring connections you're currently using for the Williams APPS (this is what Bob Weis was confirming earlier in the thread after you reported success and I'm not sure I saw you give a black-and-white confirmation this is it). I ask because I saw confusion about how to hook up the IVS component of the Williams APPS.
Williams APPS "A" White wire to OEM 4 black yellow wire (Ground)
Williams APPS "B" Black wire to OEM 3 light blue black wire (Signal)
Williams APPS "C" Red wire to OEM 5 dark blue white wire (5 volt)
Williams IVS "A" Orange wire to OEM 1 black light blue wire (Ground)
Williams IVS "B" Blue wire to OEM brown orange wire (Idle)
Williams IVS "C" Green wire to OEM 2 light green dark blue wire (Throttle or "Not Idle")
Thanks again!
John L.
